fisherman2
Hi All,
Let me introduce firstly, I'm 43years old, live in Germany and am a passionate fisherman.
Also this forum seems to be the biggest re LED and flashlights and quite plenty postings and tips can be found herein, I would have a new question, it looks like none came so far with this crazy question.
So, I need your help and I hope to get some hints and tips. It is about the flashlight I want to use on my baitboat. What is a baitboat? Well it is a RF controlled boat which serves me to bring out my fishing rigs in the water (I attach a picture). Sometimes it has to carry them a long way (200m), also during the night. Here a picture of my toy. In the mean time I changed the Walter Xenon flashlight to a no name 5W LED torch, which produces a lot of light, but the beam is not focusable and that is the problem in my case. I really need a good focusable spot. Reason being: I use the flashlight not only for front illumination but mostly for BEARING THE DIRECTION. Thus, any spill is not wanted, I need a sharp focus spot, guess 10° or so.
I thought modding a Maglite, seems to be the best solution (cheap, focusable…). Here the questions:
1LED:
- Ostart LEDs seem to have a big module (4 or 6 leds) and I learned herein that this is a con when it comes to focus.
- Next choice: a CreeQ5 or a SSC (W42180) P4, driven at ~1A for ~200Lumen output.
Which one is the better choice in a mag? I had a look in the data sheet and can't find to much of a difference, only thing could be the viewing angle, the Cree has only 90°, P4 has 132°.Should I go for the P4?
2. What reflector should I choose? Also, from where, please post some shops. As said above: sharp spot would be the best for me, no spill at all. The mag should be still focusable.
3. What heat sink? Would need a drop in module, can money buy that somewhere? Ah, the original 3W replacement module for the mag seems not that good, I red about poor thermal design and issues…
4. Please help me also on optics: reflector, glass lens, I have no clue about that. Is a reflector or a secondary optics (glass lens) better? What are the best components in terms of quality (glass, special coating etc)? Again, hints where I could buy them are welcome.
5. Driver: I need to dim the led. The boat has 6v lead batteries (14Ah), so no issue on providing the current.
My actual light on the boot is fed from the output of a receiver channel, the voltage is PWM controlled (RF) and I could easily filter it to have an analog voltage between 0V and 5,5V. But how to hook up this to a driver/converter? I need a step down with trim input. Found some having a pot but I feel I can not just drive the middle pin with an analog voltage. Would need either the schematic or even better, some hints from the board designer. Any help on this possible?
Well, guess these is my first bunch of questions. Thanks for any help!
Juergen
PS. sorry, the picture seems quite big.
1LED:
Juergen
