Focusing xenon
fishman307
Hi VERY new to flashlight fever, Just bought a ASP triad xenon, 2x cr123 It has internal focus, Is there an easy trick to set it up or is it keep unscrewing front and trying it, What should i be aiming for -- Clear clean spot at distance or what ??? ie throw or spread //
Many thanks,
it really depends on what you use your torch for. i personally prefer a clean spot unless i the bulb i am using is a x-hola in that case i prefer a creamy smooth flood :popcorn:
manual focusing of teh bulb really depends on if the filament is axial or perpendicular with respect to reflector
