Foxfury command 10 fire headlamp from LIOTEC?
TITAN1833
Dark! Dank! Murky! England.
Hi guys anyone have this headlamp? the reason I ask I just won one in JohnB's/LIOTEC give-away :D I don't have it yet as I only found out yesterday.
http://www.liotec.com/store/product_detail_pages/Command-10-Fire.htm
http://www.foxfury.com/products/detail.php?id=38
Looking at the specs on two sites I find two different max lumen's out 22+and 40+ I'm assuming 40+lumen's is correct tho :thinking:
On paper the specs look pretty good and I cant wait to try this headlamp out,what are your thoughts on it guys good or bad :twothumbs.
Oh and I'll take this opportunity to thank JohnB from LIOTEC,thank you very much John :twothumbs :twothumbs
Bought the Command 20 Tactical when it first became available. Burned a couple of sets of cells through it and now it's in rarely used. For what it is, i have no complaints. Can't tell you more as my memory of the experience is rather dim. This isn't a reflection on the impression that the light made upon me. Rather, it is a reflection on my aged memory.
I did like it better than the FoxFury Performance Outdoor model that it replaced even though it's brightness, throw, and field of vision specs are the about the same or a tad less than the Performance Outdoor model. However, in terms of size, weight (2oz less), and batt. life the Command 20 was superior, and, hence, my preference for it.
I don't use it much because for the way i used it, a smaller, lighter 3xAAA Petzl Zipka-Plus suffices and is easier to carry in my cargo pants or safari vest.
There are 2 versions of this light. This is the original version of the Command 10 AT 22 Lumens. They are very well built as all FoxFury headlamps are.
Enjoy it!
John
www.LIOTEC.com
