BB
And you cannot rotate the 60c screen like you can the GPSV.
Again, just to be clear... Mapsource is a piece of application software that runs on your PC that does several thinks:
a. Manages uploads of Map data to a Garmin GPS via RS232, USB, and various memory cards. You select the region(s) you wish to compile and upload to the Garmin (only) GPS's.
b. Uploads and downloads tracklogs, routes, and via points to Garmin GPS's.
c. Allows you to route and autoroute (and save( on your PC.
d. Allows you to use the Map data (roads, topo, etc. that you have purchased) on your PC--and you can connect a GPS to get a moving map display.
Mapsource comes "free" with any Garmin map software.
As I have read, for the Garmin 60c/cs, there are two current map packages that will autoroute on the 60c (and 70c, spiii, 26xx, and GPSV).
1. City Navigator for SPIII and 26xx with voice support--US map not available for sale in North America--must come with GPS. Apparently more support for voice based units. CN will work on GSPV and Garmin 60c etc. families.
City Select for 60c, GPSV, etc. Same basic data without specialized voice support (I think). CS North America appears to be available for $110 US or so...
In the reveiw above, the authors used the CN for testing the 60C and apparently found no problems. Because, you can get a free second GPS support.
I would call Garmin (or your local dealer) and see if there are any known issues would loading CN maps on a GPS 60c (CN maps may take up more space than CS maps because of voice support???).
-Bill
Last paragraph--swapped CN and CS to correct intent.
-Bill
