Is it possible to verify a teenager's use of the family car using a handheld GPS unit hidden in the trunk, for instance? This would be for something like verifying that he/she is going to school or work rather than someplace not allowed. Also possibly to determine if excessive speed is a problem, but this is not necessary.
Would a GPS even work in a trunk without using an external antenna?
I don't want to discuss the obvious violation of privacy issue here, just the technical. Let's assume that some proper disclaimer of limited privacy has been made. The exact method would obviously have to be secret to be effective and sometimes a parent has to make a tough decision. Using an external antenna would not be feasable unless it were almost invisible.
I have never used GPS and I assume what I am asking is easily done, but to do it in secret would be the tricky part. Accuracy would not be important, and I wouldn't expect to be able to track it in real time, but to just verify after the fact where the car was. Also, runtime on batteries might be an issue. It would need to run for at least a few hours (ideally 8-10) and if it goes dead, is the memory lost? Vehicle power is an option, but complicates things and I would like to avoid that.
Finally, I'm hoping a relatively inexpensive ($200) GPS unit would suffice.
Any advice appreciated.
