Gary123
I bought 4 of these P7 specific reflectors from Kaidomain. It makes a fantastic beam for a P7. It is part # S006537 for $3.99. Stated dimensions are 41.37 x 38.8. You can't find it on Kai's site by doing a search for the part number. You'll have to do a search for "P7 reflector" and look for the dimensions in the heading/description.
A beam shot would be a hassle, but it does give you a nice bright, small hot spot. The hotspot completely melts into the corona and then the spill. Spill is quite bright too. There is no clear delineation of the hotspot. The beam is gorgeous. You see a little of the dark crosshairs in the hotspot (from the space in between the emitters) when white walling, but it is very slight. But then you must have that with a reflector that is properly focused for a multi led emitter. The issue with the beam however, is that the spill is not a very wide angle. Meaning that the overall width of the beam is on the smaller side. A little bit of a "tunnel vision" sort of light beam, a little larger than the Tiablo A8.
If this reflector will fit one of your projects, and the head you are using is about the size for an Aleph 3 head, check it out. You might like it.
I've ordered some other P7 and MC-E specific reflectors from other sources to check out for some builds I'm having done. We'll see what's good.
