ColdZero
Hi all on CPF.
I`m looking for some advise if I may ...
First a little info from my end..
I have recently purchased :
2 x Eagletac 18650 3.7 Volt Li-ion 3400 mAh batteries
1 x Eagletac D25LC2 Clicky XM-L (Neutral White)
1 x Nitecore i4 Intellicharger
I have also recycled 5x green 18650 none protected ( possibly Sony ) not sure ? batteries from a laptop.
I discarded any obvous damaged cells after removal and also 1x that displayed next to 0 volts.
I kept the x5 that were at 4.0v...These have remained at 4.0v for approx 3 months.
These are the flat top type cells so would not work in my D25LC2 torch and were also a poor connection in my i4 charger..
So, I have soldered a little `button` on the + terminal of the cells and charged 2x for a few hours and removed them from the charger as soon as it displayed `full`.
I also kept testing the temp of these 2x cells during the charging cycle and noted that the cells felt cool to the touch through out ...
After 12 hours the voltage has remained stable at 4.21v in both cells ( same as my new Eagletac 18650 3.7 Volt Li-ion 3400 mAh after they were charged.
The green cells now fit and work in the D25LC2 but I am unsure of the safety aspect being unprotected...
Is there anything I have done incorrectly of overlooked that I should know about ?
Any info will be most appreciated.
Many thanks
Martin
http://
Many thanks
Martin
http://
