Hi All,
I've got a 10mW green laser module, its a 3VDC model, and I'm running it with 2x 1.5v D Cell batteries. I'm using it to generate a line to guide a saw blade. That part works well.
The multimeter says its drawing 280mA, which seems about right from reading these forums.
What's happening is:
Especially first thing in the morning, when its cooler in the workshop, it takes about 5 minutes to become bright. Firstly, is that a function of the battery not outputting enough current when cool, or it something more to do with the laser module?
Also, after being bright for some time, say 5-10mins, it fades down again. Switching it off, leaving it for a minute, and turning it on, restores the brightness, for a while until it fades again, I can repeat this over and over. Again, is that from the battery slumping, or from the laser perhaps overheating and powering down?
To get it to start-up faster, and to run longer, I'd consider either lowering the current (it doesn't need to be as bright as it is), or running it on mains power where I can supply a regulated current. What do you think, can I even restrict the current it draws?
Thanks for any and all help!
