H1 bulb high performance options
MichaelW
USA
Seeing as the industry has installed the H9 burner in the H7 bulb format ["rallye"], what is the chance that the same burner will be installed in an H1?
Baring that, what is/are the options to get 2,000 lumens or better?
100 watt H1 should get you 2500 lumens, 130 watt h1 over 3000 lumens IF your housing AND wiring are up to the task.
Thanks for the response, I should of added I'd like to get consumption/heat to 70 watts maximum.
No. Physical incompatibility prevents it.
You can get pretty close with Philips Xtreme Power or Xtreme Vision (about 1750 lumens or so, without looking).
Remember the negative effect on beam focus from going to higher-wattage bulbs (due to larger filament coil).
