CathastrophiX
I have fixed mine so it works with protected batteries without malfunction.
Mine had several problems, which was a pity since I really like the light.
- Low set to 3, only switching between Med-Hi, as several others have experienced.
- Sometimes it only came on in low, I couldn't change modes.
- Somtimes had to take out the batteries to shut it of.
- When in "110" mode, it sometimes would shut of after a couple of minutes.
- Sometimes flickered in 0.5 and 3 lumens mode.
- Sometimes it didn't light up, unless I removed and installed the battery again.
- Sometimes it light up and shut down immediately again.
Since the battery tube is a couple of millimeters longer than the batteries I tought protected batteries should work. First I put a copper wire in the endcap, then tried to solder the ring in the end cap to make it thicker, because I tought the threaded part was to short to make good contact, but it made no difference.
I ordered AW batteries because I tought my Ultra- and Trustfire were to long (AW's batteries are the same lenght)
Since I felt that the spring put alot off pressure on the battery, I got the idea to shorten the spring (since I don't plan to ever use unprotected cells) I also removed the solder from the ring.
Now it works perfect, I have not had a single malfunction since I shortened the spring.
Finally I can be really happy about this light! :laughing:
Disclaimer: This fix worked on mine, I can't guarantee it works on yours.
Try it on your own risk.
