Sold/Expired HDS B42XR SeoulModded **GONE**
Groundhog66
Banned
Bay Area, CA
Modded with a SSCP4, and the body is MINT. I am letting this one go pretty cheap due to the fact it has the dreaded HDS buzz on some levels. It buzzed when I got it, it still buzzes after the mod. If you hold it close enough you can hear it, holding it at normal position I couldn't. None the less, it is a great light. I have the Force Mode turned off, therefore it remembers the last brightness. I also have it set to Simple Momentary Mode, which means if you press and hold the button it will automatically turn off when you let it off. This 42 is as bright as my modded 60LE, but it has a bit warmer tint. Send me $150 NOW JUST $135 and it's yours. The beamshot was taken this morning, hence the light behind the shade.
Re: HDS B42XR SeoulModded NOW $135
:wow:
Who cares if it buzzes, hisses, or tries to bite you. $135 is a great price!
- Chris
