KrisP
Hi,
I have a cheap 40 LED headlamp sitting around that i'd like to put a Seoul P4 into. The headlamp takes 3AA and has a soft button switch that turns the middle 5 LED's, then another press turns on the next ring and another press turns on the rest of the LED's. If possible, i'd like to keep that function for the replacement Seoul so I can extend the runtime if needed and not blind fellow campers. I'd like to make the first setting 100-200mA, 2nd setting 500mA, and the final setting 1A.
Firstly, if I was just going to run at one setting, say 500mA, and used a current reg to limit that, would I have any issues with the 3 fresh NiMH that might be at 4.5v rather than 3.6v? Or would I need a voltage reg as well?
Secondly, is there any pre-made boards I could just buy and fit to make sure it's going to work OK?
I'm only after flood, so does the Seoul need a reflector? Can I just mount it in place of the old LED's and let it spread it's light everywhere and still have usable light?
Thanks in advance
Thanks in advance
