Help finding replacement clicky for Aurora M3-2
whiteboyoffthelake
I own an Aurora M3-2 that I bought a little over 5 years ago. It is a simple two-mode, high/low light. Recently the light started flickering. Over time the flickering got worse until now I get nothing.
I cleaned all the threads. I followed all the instructions here http://www.candlepowerforums.com/vb/showthread.php?227518-LED-Troubleshooting-guide-(budget-lights), but nothing changed. The light passes the paper clip test so I believe it is the clicky - note it "clicks" fine, the light just won't turn on.
I'm having difficulty finding a replacement clicky. I'd attach a picture but I'm not permitted to include attachments, but it is similar to this one http://www.bestofferbuy.com/17mm-re...p-78547.html?zenid=ii5nr3cjiepokb1dvjiu6cdta7, except that mine has a blue-colored resistor next to the black button with blue, grey, gold and gold stripes.
Also, it is a forward clicky.
Does anyone know where I can find a replacement?
Thanks.
Try tighening the retaining ring and see if that will fix it. If not, find an after martket switch with the same OD and should only take a minute to swap.
Barry
Thanks for the quick reply...
I tightened the retaining ring as tight as could reasonably be accomplished, but that did not fix the problem.
Forgive me, but I'm not sure what "same OD" means. I tried looking around the DX site more and found a 2-mode clicky that looks like an even closer match to mine than the one I linked to above - http://dx.com/p/replacement-2-mode-clicky-switch-for-c8-flashlight-black-silver-green-219020 - but this one also does not have a resistor, so I don't know if it will work. The description says it's for a "C8" flashlight, but I don't know if mine is a C8 or not.
A link to DX's page for my light is here - http://dx.com/p/aurora-m3-2-cree-mc-e-bin-m-wc-2-mode-led-flashlight-1-18650-16540. It appears to be direct driven on high and (obviously) by a resistor on low.
This light suits me just fine, so I'm hoping to be able to fix it rather than having to buy a new one
Thanks again.
The OD was for the outside diameter of the switch. I was thinking that it was a standard switch and the modes were controlled by a driver in the head. If you put in a stardard switch, you would have high only but would make the light functional again until you find another 2 mode switch. Can you open the head and instal a 2 or 3 mode driver between the LED and battery contact?
Might be worth a trip to local electronics store to get another resistor and see if that would fix it.
cnqualitygoods and intl-outdoor.com might be worth looking at too.
Here is the link to the marketplace thread on your light. There is some contact info at the bottom that may help you as well.
http://www.cpfmarketplace.com/mp/showthread.php?243598-Aurora-MC-E-E-high-powerful-led-torch
Hope some of this helps,
Barry
Are you sure it is a forward clicky?
Most of the 2 mode lights are reverse clicky.
