Recently I purchased the CEN-100-20 mean well driver (datasheet here) This driver is versatile since current and voltage can be varied (3.12-4.8A, 17-22V).
My circuit needs 20.7V and at 4.1A peak (average 2A or less). There are two screws for voltage/current adjustment. But how do I set them? Do I just connect multimeter probes to the outputs and turn the screws? Or do I need a proper load and measure the voltage across it? I realize this driver has CC-CV mode which makes things complicated.
EDIT: I guess the voltage and the max current values are factory set at the default values (i.e. 20V and 4.8A). So maybe I need to tweak the voltage screw only.
