MikeG1P315
- Joined
- Feb 16, 2006
- Messages
- 149
As the title says... I've recently lost my Photon Freedom CS and am looking to replace it. I am aware that the first response of many will be "they're completely different!" so before you hit that reply button, let me state my quandry:
With rare exception I used my Freedom on max brightness. So the ramping feature is not a big deal to me. The few and far between occasions I used a lower brightness I could have just as easily used the max, so this is not a concern to me, otherwise the choice would be easy.
Obviously the Freedom is smaller, but the Arc AAA is not overly large, so this also is not a primary factor.
Also, I am aware the Arc AAA is 2x more expensive up front, but if the AAA battery (which is cheaper) will run the light at max longer than the 2x2016 (which is more costly) in the Freedom, the initial cost will be more than compensated for over the life of the light.
Primarily, I am seeking input with regard to overall brightness (which is brighter? Freedom or Arc AAA?) and runtime (which runs longer at max power? Freedom or Arc AAA?) and durability (plastics of the Freedom vs. construction of the Arc AAA.) Your input is greatly valued! Thanks everybody!
