MedusaOblongata
I've been EDCing the same copper Lumintop Prince for 3 1/2 years, and it's starting to become unreliable. Sometimes it won't turn on, sometimes it will change modes randomly. I figure these lights don't last forever.
I carry it in a leather pouch in my back pocket that also holds a LM Free P4 and CRKT Ripple, so size is very important. It needs to be no longer than 4.6" (117mm) and no wider (at the widest point, not counting the clip) than 1" (25mm).
I would prefer a light that can take a 18650 or primaries.
Clicky tailcap switch is a must.
My use of it is what you would call general. Sometimes indoors, sometimes outdoors, sometimes I need just a few lumens, other times bright is good. Moonlight mode doesn't matter, I've never found 3 or 5 lumens to be too bright.
A little bit more throw than flood, but not looking for a throw monster and definitely don't want a light that gets too long or wide for my pocket.
Infinitely variable brightness would be great if possible (I liked my old Nitecore IFE2 and Sunwayman V10R), whether through ramping or a ring (or another method?).
I carry the same light every day, I neither baby it nor beat it up much.
I'm not a tint snob.
Price range should be under $100, and I'm definitely not looking for something cheap and unreliable.
Weight is not really important.
A slightly crenelated bezel is fine, but I don't want alligator teeth.
I do like copper, but that's really not an important factor.
I'll probably carry the thing every day until it stops working well, or until it feels outdated in 5 years and I can get 3x the runtime and lumens in the same size.
I've seen some threads and videos of the FW3A, but they're over a year old. Is that a good choice?
Thank you,
Thank you,
