Hi folks,
Turning to the experts. I have modded an 120 Ra twisty from P4 to an XPG2 LED. All has worked out just fine. LED installed. No shorts that I can find. Light turns on ok in low and medium, but when I turn to high, it does this low-to-high blinking thing and ends up on a high that is fairly close to the medium. I have done a factory reset where you twisty the head on quickly within 2 second and wait until the light turns off after ten seconds. Worked fine.
I just can't seem to get the high to work well.
I have cleaned out the switch mechanism as best I can and it does make contact sine when I get to high it does something, just not what I think it should do.
The other weird thing is that when I leave it on high, it does a double blink about every 60 seconds.
Any ideas?
Thanks,
eala
Any ideas?
Thanks,
eala
