Hi there everyone
I'm looking at getting myself a Solarforce L2P, and running it off a single 18650. Just before rushing off to ebay and buying a battery and charger I thought I'd look here and have a read but now I'm getting confused and concerned that I'm not going to be able to understand the whats and hows of it all.
I'm looking at getting a 400+ lumen pill, and just using a single 18650 battery. I was thinking that getting a 3100mAh would be the go, but now I'm not so sure. I looked for a very basic rundown on battery info and couldn't see anything that made sense to me, so I thought I better ask here.
I will primarily be using this light at 10% and 40%, (50 and 200 lumens) for half hour and up at a time, rarely longer. I live in a cold climate if that helps. I would like long run time and performance, but I don't have a lot of money to throw at chargers and testers etc.
I will be getting a low volt pill as I don't plan on running anything but a single 18650
so does the higher mAh rating = greater run time, or is it the volts, or is it neither?
what I was looking at getting off ebay, was this
1 x NEW Protected Ultrafire 18650 LI-ION 3000mAh 3.7V Rechargeable BATTERY + XTAR MP1 USB Charger
Is this a reasonable battery and charger set up?
I read a review on the charger, and it seemed to have overcharge protection etc, downside was slow charging. I don't mind the slow charging as I would have two batteries on rotation.
What would be the best battery for my application, AW brand? Solarforce batteries or are these Ultrafires just fine? The fully charged battery would sit in my crib bag for maybe a week or two before being changed (well that is a guess, I currently change my batteries every second work week) so I'd like something that can hold its charge.
Is there a setup I can get that is USB charging (because Australian spec power plugs are expensive) as well as a pair of batteries for around 50 bucks? I don't mind spending decent money initially, but I don't want to have to keep getting bits and bobs to keep up with my batteries.
I guess its more of a "recommend me a good, easy to maintain battery and charger for this application" thread more than anything.
I would like to learn the science behind it all, but I don't have the time to fully educate myself at the moment and I'm on the hunt for a light/battery setup now. In a couple of months once I have moved interstate and life has gotten settled again I will make a great effort to learn it all, but right now I could really do with some help.
Thank you all in advance
