V2,
make sure when using that SSC twist module, the battery positive is toward tailcap****
Hmm looks like aa CL1H 1.0,one way to check for sure is the dimensions thus:
the CL1H 2.0 140mm(Length)x 34mm(Head)x 25mm(housing).The CL1H 1.0 is about 10mm shorter if memory serves ;)
[EDIT] yes orbital and Helmut.G are right V2
here's a V1
What pill? IIRC only the 2SM had reverse polarity i.e + toward tail cap, the digital/newer pills use a forward clicky to change modes/light levels in that case + toward head hope that helps.thanks...how about the battery terminal direction when i change the pills? thanks again.
It works with 18650 as well as 2xCR123 and 2xRCR123, but I think it's not really regulated well on 18650sHelmut.G- another thing, does the one you have with the SSC only work with 18650's? mine only works with 18650's so far. thanks again
