Help with a mountable, powerfull spotlight (My first post!)
CapeDoc
Hi from Africa!
(My first post, please be gentle)
I need advice regarding a powerful spotlight, that can be used both while in a mounting that will hold it steady and that may be used from a vehicle (with or without mounting) to spot game.
The light will be used in 2 ways:
- From a fixed structure: From here, when spotting game, it would be useful to place the light in a fixed or hanging swivel mount which would hold the light steady whenever needed. (If you spot an antelope lying down, the mount can hold it steady while you look through binoculars).
- From a moving vehicle: hand held, scanning around the vehicle as it moves. If a stationary animal sighted, it would be nice to quicly fit it to a mount, again, freeing the hands for use of binoculars.
To answer questions from the sticky:
____I would like to purchase the light from a brick and mortar store. I am located in ______________.
____I will be mail-ordering or buying online, so this doesn't matter.
I will probably order online as availability is limited in Africa
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
____Less than $25.
____Less than $50.
____Less than $100.
____Less than $150.
____Less than $300.
____I have no limit.
____I’m flexible, tell me what you gotJ.
____Other, please specify ________
I would be prepared to spend up to about $400
3) Format:
____I want a flashlight.
____I want a headlamp.
____I want a lantern.
____I want a dive light.
____I want a portable spotlight.
4) Flashlight-specific format/size:
____Keychain size.
____Every day carry small (2-4 inches).
____Every day carry medium (4-7 inches).
____Holster carry.
____Big enough to need its own travel caseJ.
____I don’t care.
____I don’t know.
The weight of the light is important as it it may be needed to be held for a few hours. Heavy lights would not be option. This is the most important feature: the light must be as lightweight as possible
5) Emitter/Light source:
____LED (known for efficiency, longevity, and compactness)
____ doesn't matter too much, best for viewing game.
6) Manufacturer:
____I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
____I would consider getting a light that is pieced together (for example a “host” or flashlight body from one manufacturer, and a “drop-in” emitter from another source). Under the right circumstances, this path can provide more options to the consumer to meet specific needs, and can often be easily upgradeable as technology improves.
Will take your advice.
7) What battery type do you want to use?
____I intend to use alkaline batteries (AAA, AA, C, D) (disclaimer, while it does not preclude all choices, these are not recommended for many of today’s most powerful lights)
____I intend to use rechargeable nickel chemistry (NiCad, NiMH, NiZn)
____I intend to use lithium primary batteries (CR123, CR2, Energizer Advanced/Ultimate Lithium AA/AAA)
____I intend to use rechargeable lithium (li-ion) chemistry. Feel free to specify a size if you know which size you want (14500, RCR123/16340, 17500, 17670, 18650, etc.)
____I want a light with an integrated rechargeable battery. (Note: these choices may be very limited unless you are looking at spotlights)
There is an option to connect it to a car battery for extended use. It could be recharged. Otherwise the best option would be a standard battery, that could be easily purchased anywhere in Africa
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
____I want to navigate a dark room or read a map (0-10 lumens).
____I want to walk around an unlit rural area (50-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want ridiculous amounts of lumens (800+ lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
____150+ yards (I want maximum throw possible)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
____30-60 minutes (I have plenty of batteries just ready to be changed)
____90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
Long periods may be necessary. Current light uses a car battery which charges itself. Mains power is an option
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
____Not Important (A “night-stand” light).
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't care.
____I don’t know.
12) Switch Type and location (choose all that apply):
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today’s high end lights).
____I don't care.
____I don’t know.
____A simple on-off with only one output level is fine for me.
____I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
____I want a strobe mode. (Blinks to show location.)
____I want SOS mode.
____I want a beacon mode.
____I don’t care.
____I don’t know.
14)Material/Finish/Coating
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
____I don’t care.
____I don’t know.
As light as possible
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
____Red filter (for preserving night vision). would be nice
____“Hybrid” light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking Intrinsically Safe (IS) for use in explosive environments
The main features needed:
Lightweight
Big Output
Intimate relationship with a versatile mount (I suppose half of my question is: What is going to be the best way to mount it?)
Can run fro mains power or 12Volt supply.
Thanks for letting me ask!
Heres two lights which are rather expensive, but are considered very good:
-The Maxabeam: Extreme throw (maybe 3 Kilometers?) small intense hotspot, around 1500 lumens I think, is mountable and can be run with 12V, 24V, 48V DC or 100-240V AC or using different types of batteries (definitely take a lithium-based battery for light-weight)
-The Polarion Night Reaper: less throw, but still a lot, over 5000 lumens, is mountable and can be run with different power sources including lithium-ion batteries.
Both of these lights are very expensive, but are considered the best in their fields and will easily beat any led light you will find.
Thanks for the reply! I checked out the suggestions, they look like two amazing lights!! I do think those two are a little out of my price range and possibly a little bit of an overkill. Any other suggestions?
Take a look at the lightforce blitz sl240, they use a rather primitive incandescant krypton bulb but still manage to throw 400+ yards of useable light. Can be vehicle mounted or be portable with a detachable 12 volt battery pack.
