Ok I have a simple set of requirements. I have a dimmer circuit which can have a maximum of 300w through it and I want the maximum lumens out of this setup with an off the shelf medium base bulb.
I'm a photographer and I'm setting up a studio and lighting it with medium base lights. I've been using 300w incandescent bulbs on 300w dimmers but I'm not getting a bright enough output at each light to make this setup work. I'd be perfect with double the light output in my setup.
I was thinking I could either get a better bulb or mount an extra dimmer and an extra bulb co-axially but then I'd have to do a lot of fabrication and this would distort the way the light falls on what I'm photographing. Furthermore I'd have a much harder time using reflectors as these are always designed to wrap around one bulb.
It wouldn't be economical if a better bulb costs more than $35 per unit as after that price point I'd probably be willing to go with fabrication. I'd appreciate some help finding what the most powerful dimmable option I have is.
