Packhorse
http://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=4345
I have the above PCB which provided balancing of cells.
I just built a 3p3s pack and wired this up and get no output voltage.
I tested all the input wires and it is wired correctly. I Tried a second PCB I have but same outcome.
Upon reading the product description it says
I supose I will know in 20 minutes :whistle:
Does this mean the pack is not usable for 30 minutes after charging or you should wait 30 minutes after charging?To achieve balance, each cell in battery pack must have equal voltage within tolerance of 0.2V. After charger LED turn Green, unplug charger and wait 30 minutes before use. This is for the pack to perform balance function.
