txwest
I had seen them mentioned here, but never noticed if anyone has done a run test. I bought (3) 9000mAh D batteries from C.Crane to go with my DD Triple Blaster Wayne is supposed to be sending me. He said at 4.5V he had measured one of his pulling 1.7 amps. I'm guessing that at 3.6V it will pull around 1.2, so I'm running a test right now with my 3D Mag & Mag-Star lamp, which I believe is 1.2 amp draw. For some reason, the package this bulb came in says not to use rechargeable batteries. Anyone know why?
Last night I ran it nonstop for 4.5 hrs. Didn't check the batteries then, because it was 11:30. I tested them with the C.Crane charger when I got home this afternoon, & was supprised at the outcome. The C.Crane charger tends to be conservative on the "power level" of the batteries when you test them. I can take a C battery I know is less than 1/2 "used" & the charger will show no bars of "power" left. So after 4 1/2 hrs on this load, I expected the "bar" level to be showing low. To my supprise, the power level was showing the max of 5 bars on all 3 batteries, & all showed 1.3V. I turned the light back on at 5:00 & it is almost 9:00 now. No noticeable change in the light output. If anyone else has experience with hi-cap D's, let me know. TX
