Bright lights and a stout brew before 9am
..okay back to painting my shed✌️
That picture was taken shortly after the XM18 arrived. It was January of last year around 4:30 pm ... not that there's anything wrong with day drinking.
Thanks @DaveTheDude for your thoughts.If the criteria include both flood and throw, may I ever-so-gently suggest that you consider two lights, with one of them being a dedicated thrower? Many excellent throwers don't require 2000+ lumens to illuminate at distance, and even if the thrower uses a cool white emitter, a high CRI isn't going to be of much real use at distances greater than 100 meters, because you're not likely to be able to perform much in the way of color separation at that distance anyway. My reading of the posts above suggests that two separate lights - one high CRI with a broad beam pattern, and one dedicated thrower - will satisfy the mission objectives better than a single light. Also, a single light combining the desired capabilities will of necessity entail significant compromise in the design, come at substantial cost, or both.
It's not my intent to rain on the parade; I'm just focusing on the mission objectives.
I'm not sure how much confidence I would have in those output numbers - the Cree XHP50 is rated for about 2300 lumens for a top bin running at maximum rated current, and that doesn't count the losses in the reflector or lens. OTF lumens for an XHP-50 with realistic binning are going to top out at around 1800 lumens for the package being driven at max rated power. Now, it's possible that Jetbeam opts to drive the LED beyond the manufacturer's ratings for their turbo mode, in which case I'd be worried about longevity. It may be just fine for the expected number of hours of operation, however.The T4 PRO is a 2,580 lumen hand-held light that uses 1 x 26650 cell, powering a Cree XHP50 LED.
Turbo mode requires a high drain battery. After about six minutes on the turbo setting the output will decrease to somewhere in the vicinity of 1800 lumens, and at the ten minute mark it will have declined to the 1000 lumen output level, and will remain steady at the 1000 lumen level for about two hours.
Max run time is 85 hours at the 50 lumen level. The light uses a constant current circuit. IPX8 waterproof rating.
That and the XHP50 is far from being renowned for its CRI.I'm not sure how much confidence I would have in those output numbers - the Cree XHP50 is rated for about 2300 lumens for a top bin running at maximum rated current, and that doesn't count the losses in the reflector or lens. OTF lumens for an XHP-50 with realistic binning are going to top out at around 1800 lumens for the package being driven at max rated power. Now, it's possible that Jetbeam opts to drive the LED beyond the manufacturer's ratings for their turbo mode, in which case I'd be worried about longevity. It may be just fine for the expected number of hours of operation, however.
I can't speak to everyone's experience with Cree XHP50, but the runtimes I cited are the ones I experienced in my use of my Jetbeam T4 Pro. I find that for me, this light is best thought of as being a good, solid 1000 lumen light, with a five minute, 2500 lumen turbo-burst mode available when additional photons are desired (assuming the battery is not too depleted to deliver the required current).I'm not sure how much confidence I would have in those output numbers - the Cree XHP50 is rated for about 2300 lumens for a top bin running at maximum rated current, and that doesn't count the losses in the reflector or lens. OTF lumens for an XHP-50 with realistic binning are going to top out at around 1800 lumens for the package being driven at max rated power. Now, it's possible that Jetbeam opts to drive the LED beyond the manufacturer's ratings for their turbo mode, in which case I'd be worried about longevity. It may be just fine for the expected number of hours of operation, however.
The turbo setting declines gradually, almost imperceptibly, over the first five minutes of use, from 2500 lumens to 1800 lumens or thereabouts, then over the next five minutes gradually declines to about 1000 lumens, where it happily stays stable for the next two hours.I think having five minutes of turbo would be awesome! This is the first I've ever read of such a prolonged turbo period.
I believe the Zebralight SC700Fd uses real-time thermal throttling, meaning you can extend the turbo time significantly (several minutes) in colder temperatures, or even depending on how you hold it. Very nice in my opinion, although I don't (yet) have hands-on experience with it.I think having five minutes of turbo would be awesome! This is the first I've ever read of such a prolonged turbo period.
Not sure if You know, but Foursevens is still much alive. Contact them directly at Support(@)Darksucks(.)com for personalized support regarding your concerns and questions.Ha! Found it!
In closing a bunch of browser tabs from this little research excursion, I revisited the Acebeam X50 2.0, and discovered that if you hold your tongue right while viewing their website, they do a 95+ CRI version, advertised for photography. It's a much lower output than the Cree emitter version (but still absolutely stupid-level lumens), and gets super hot - but will hold a steady output about 2000 lumens for well over an hour without cooking your egg too quickly.
It is at the top end of the size profile I had in mind, but hey, physics, right? I don't know how well the Getian GT-FC40 emitters will hold up at the temperatures Acebeam are allowing this light to reach, but someone's got to test it - I volunteer as tribute.
X50 2.0 High CRI LED Photography Fill Light
Photographer's Best Friend. ACEBEAM X50 Photography Fill Light is the best tool to make sure your photos turn out perfect!www.acebeam.com
The only real downside to all of this is that Acebeam are out of stock; and I no longer have an excuse for the unexpectedly expansive contents of my Foursevens shopping cart…
Yep. I have a very high regard for Jason and his work, as well as David. I confess I did find one outlet in Canada with stock of the Acebeam X50 2.0 High CRI, but after much procrastinating, I couldn't quite bring myself to buy it.Not sure if You know, but Foursevens is still much alive. Contact them directly at Support(@)Darksucks(.)com for personalized support regarding your concerns and questions.
GL
