flashlightsarecool
- Joined
- Mar 14, 2014
- Messages
- 70
I own a thrunite mini tn30. I just saw a review on YouTube. With a cooling fan it gets up to 157 degrees F in under ten minutes. The panny 3400's are only rated for 60C (140F). Will the protection circuit in the battery trip if the battery gets too hot or does that only work in extreme heat like a short circuit? Should I switch to imr's that are rated for 75C (167F). I don't run the light in turbo for extended periods but id like to have batteries that can tolerate more heat. Thanks.
