High Power Laser Diodes
Thanks but I already sent a mail to him /ubbthreads/images/graemlins/smile.gif .
can i use that 1,2w diode with my laserpen chrystals ?
if not.. what do i need t make that stuff work ? /ubbthreads/images/graemlins/smile.gif
thanx
I think you mean your laser pointer crystal set... So I am going to respond from that perspective.
While you CAN use them with the rocks in the laser pointer I wouldnt expect them to last very long with the massive amount of photons your trying to push into it without a impressive cooling solution that would rather destory your want to have it fit in your pocket.
That is unless you wear some of the older jnco's I used to see kids wear with the 2ftx2ft pockets in them. heh /ubbthreads/images/graemlins/wink.gif
As usual if you have any more questions feel free to ask.
I found a diode :
>Package: C-mount Open Heatsink Package
>CW Output Power: 2 W
>Center Wavelength: 808 (±3) nm
>Spectral Width: 2 nm
>Slope Efficiency: 0.9 W/A typ
>FWHM beam divergence: 12 degrees parallel, 32 degrees perpendicular to junction
>Threshold Current: 400mA typ
>Operating Current: 1.6A typ
... 1.6A seems to be low, isn't ? Do you think it is possible to produce 2W of 808nm light with these specifications ? All the 2W laser diodes I've seen used 2A or more (often 3A max)...
Care to offer a link? Company? Anything? /ubbthreads/images/graemlins/wink.gif
The electrical characteristics of this diode are a bit weird. I would also assume far greater electrical demands, though I could see it being possible if lots of crazy design specifications are met.
Now, If I could only find a diode like this in a TO56 package.
