Hog Hunting & HD Weapon Light
c0nspire
I am looking for a rifle mounted light (AR-15) that will be used mainly for hog hunting. This rifle is also my go-to for anything that goes bump-in-the-night in and around my home and surrounding property (mostly rural).
I would like something that can throw out to 200-250 yards, but still has a little spill (doesn't need a ton). If the light is nearly ALL throw (like the ArmyTek) it would be nice if I could add a diffuser for the rare occasion the light may be needed indoors (SureFire FM14 or something similar).
I don't need a strobe or any other "vegas" modes. Don't need ton of settings. I would like a "max" primary mode and "medium/low" secondary mode for navigating the house or wooded areas.
I have considered the ArmyTek Predator V2, Thrunite Scorpion V2 w/Turbo head, and the TN11S. I also looked at the Klarus XT11 but fear it won't have the throw I'd like.
What else am I missing? Pros/cons with the lights I'm looking at and/or other's I should be considering? Am I being unrealistic with any of my goals?
Thanks in advance!
____Mail-ordering or buying online... doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
____No limit
3) Format:
____Flashlight/weapon light
4) Flashlight-specific format/size:
____Needs to have a 1" body
____2 CR123's or a 18650, nothing longer
5) Emitter/Light source:
____LED
6) Manufacturer:
____Buy or build, I'm ok with either if the quality is there.
7) What battery type do you want to use?
____CR123, 18650, open to others…?
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
____Walk around an unlit rural area (50-150 lumens).
____Illuminate my entire backyard or a campsite (150-300 lumens).
____Illuminate a field, the neighbor's front yard several houses down (300-700 lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
____Anything from 5-200+ yards, but primarily 20-200 yards
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
____60-120 minutes (Runtime is moderately important, but still not critical)
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
12) Switch Type and location (choose all that apply):
____I need a forward clicky/momentary tail switch
____I want 2 light levels (bright and med/low). If there are more but the UI doesn't force me to navigate them, that's ok. A single-mode light could also work.
14)Material/Finish/Coating
____I don’t care as long as it's durable
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
____Red filter could be handy for hog huting but not required
____Diffuser could be handy if the light has little or no spill to begin with
____Prefer the light is as light-weight as possible
____Head cannot be any larger then 1.75" or so
Hope that AR is a .308 for the hogs. wouldn't want to pizz one off at night with a 5.56/.223:whistle::)
