Homemade battery tester??
lightwait
New York
Hi guys,
This has probably been discussed before but I'm not coming up with anything on a search. I'm wanting to test CR123 batteries but not wanting to buy a tester. I don't use tons of 123's and pretty much stick to single cell lights.
I have meters, high-power/low-ohm resisters, etc. Is there an agreed upon quick test to judge the condition of the battery? I'm looking for maybe a chart or something that relates initial voltage across a known load to remaining battery capacity.
For starters, I tested voltage and current from a some 3 year old CR123's with a 12v car tail light I had laying around. All batteries I had put out about 1.1 amps at 2.2 volts into the test lamp. I'd like to get more professional and use maybe a 3 ohm resistor or something in that range. I know I have a selection of them packed away somewhere. Thanks for any tips.
