Not sure if there is one, I was just pointing out the efficiency comparison if there were one....
There are some options in the "range" (all using 2 CR123s, just for direct comparison to the X5). Lets call the X5 30 lumens for 6 hours to 50%, but keep in mind that it can probably last another 20-30 or more hours at a small fraction of the initial output... it's not really a regulated light, it's basically a resistor direct drive setup (which has the advantage of being very reliable, and having plenty of hours of dim emergency lighting after the batteries are mostly depleted). Many of the lights in the list I will make below, have pretty flat regulation on 2xCR123s.
(keep in mind that these are all manufacture ratings, so reality can vary some, most of these manufactures are reasonably reputable and are going to at least be in the ballpark of accurate output and runtime, some may be emitter lumens instead of torch or vice versa, there is always some variation based on the LED lottery)...
Medium on the LumaPower Encore, 55 lumen for 9 hours
PD30 has a 70 lumen for 8 hours mode
TK10 general mode 60 lumen for 10 hours
P3D has 53 lumen for 13 hours mode
Tiablo MA6 A6 has a 50 lumen for 10 hour mode
Olight M20 premium has a 90 lumen for 12 hour mode
Olight T20 45 lumens for 10 hrs or 18 lumens for 30 hrs (2 of the 5 available modes)
E2L is advertised at 60 lumen for 11 hours on high,
L2 advertised at 15 lumen for 18 hours on low.
This is just a few examples I can think of right now....
I think a manufacture would do well to release something like an X5, a simple, single mode low output LED light based on an R2 emitter, with say, 30 lumens for 30 hours regulated on 2 CR123s (this should be possible).
Eric
Eric
