The amount of current most cellphone li-ion batteries can put out is also somewhat limited.
A small cellphone battery may simply be able to direct drive that luxeon.
Ever notice how some li-ion cellphone batts drop considerably in "charge remaining", after a short conversation?
And then comes back up a bar, or two?
Many of these batteries can only supply a limited amount of current.
Many cellphone batteries are not the high output/high quality ones, like the Pilas that jsburlys has.
Assuming that your luxeon has a nice 486 sized heatsink block to mount onto,
this may be simpler for a circuitboard greenhorn.
#1 Try a high wattage reostat variable resistor in series with that setup, with a series amp meter, until current stays just under 350ma no matter what.(less is ok, if you don't mind it being dimmer and cooler running)
#2 Then measure the reostat's ohm reading.
If you have the reostat at near zero added resistance, then you may direct drive that badboy, and can skip the following steps and enjoy it in direct drive. /ubbthreads/images/graemlins/thumbsup.gif
If there is some added resistance, read on.
#3 Go get a couple 1/4 to 1/2 watt resistors with the same added resistance for the luxeons, and carefully solder them into the circuit with electronics solder, and a small 25 watt soldering iron.(not your grandaddys 100 watt one)
#4 enjoy. /ubbthreads/images/graemlins/smile.gif
