I know it is supposed to unscrew but mine doesn't. Is it glued? Is there a trick to it? Pics would be fabulous.
Thanks
As for mine I unscrewed the bessel and took the assembly out. The pill assembly has reverse threads so you will have to twist it the opposite direction. If you want the actual led out you will have to twist off the reflector with pliers, it is glued. That will expose the led. If I remember the rest unscrews as well but if you are just swapping out the pill assembly for a new one it is reverse threads.
I dont understand how or where to unscrew the entire unit to replace it?
