HS2 headlamp introduction and launch
Olightworld
At Olight, we believe it is necessary to have the best tools possibly to support living an active lifestyle.
The HS2 is one of the most compact and lightweight headlamps on the market built for night running, hiking, or any other active need for hands-free light. We also made sure to have the light feature a bright beam with great runtimes including a maximum of 400 lumens and a runtime of 18 hours with a dual LED system supporting either long range or up close and wide illumination.
The battery pack can be charged via micro-USB or you can power the light directly and bypass the pack if it runs out of power with any USB power source. When there is 10% battery left, the HS2 will begin to beep and alert the user without having to take the headlamp off to check.
Whether you are just getting started or conquer the night 7 days a week, the HS2 will help you reach any active goals you've set your mind to.
CURRENTLY AVAILABLE FOR PRE-ORDER AT
https://www.olightstore.com/led-flashlights/headlamps/headlamp-olight-hs2
  • Can be powered directly from any USB power source; never run out of battery.
  • Dual LED system for long range and up-close wide illumination.
  • Audible beep at 10% battery capacity to alert the user to charge.
  • Super lightweight at only 4 ounces. It is made of lightweight aluminum alloy with a compact uni-body structure.
  • Wide illumination area. Its dual LED light source with TIR optic lens give either independent low beam (close-range light), high beam (far-range light) or a mixed beam combining both of them.
  • Great runtime. It has a 2000mAh Lipo battery pack that supports a runtime up to 18 hours for continuous use.
  • Alternative lighting easily available. In case the provided battery pack runs out of power, the headlamp can still be powered by any external Micro-USB power source and resume normal work by plugging the charging cable to it, further extending its runtime.
  • Smart power level indication. Four-level battery power indication and low-power beeping sound warning in addition, helping to keeping you updated of the power status.
  • Gradual brightness changes. When turned on/off or changing modes, the brightness will change gradually to protect eyes from the stimulation caused by sudden brightness changes.
