Robocop
Mammoth Killer
I can not believe this actually worked.A few posts back I posted about a clip on 3 LED light made by night blaster.It uses 3 AA batteries in a barrel type holder.It was very bright for an off brand and I immediately tore it apart.I took the head unit out and it is one unit holding all 3 LEDs inside a sealed reflector.The contacts are flat half circle areas on the bottom.If you file a little aroung the edges it will drop right in to the head assembly of a AA minimag The lens part then can be screwed on to hold it tight.I then took 2 small pieces of wire and placed each in to the pin holes where the original bulb was placed.Bent each one opposite from the other and put a small drop of solder on each one.If you screw the head down carefully it will contact both pins and yes it worked I had to use 3 n cells to power the 3 LEDs but it is almost as bright as my Inova.I used a kroll clickie switch and it works perfect.I will try to get some pics soon but I have to first learn how to post pics.The reflector is very bright and the beam is smooth and very white.I got the blaster clip on light at Wally world for about 7 or 8 dollars.I now have a fairly bright light using 3 LEDs.....this is so addicting
The entire project took me about 30 minutes.I do not think this is a very reliable set up as the contact points were hard to get dead on however I am sure someone here could improve my idea.......I am hooked
