I received my two 500ma SLS hybrids yesterday. The tint on both is slightly yellower that the two 400 ma flex failure fixed SLS that I received a few weeks before - those ones were pure bright white with a slight blue corona - just as white or even whiter than my LS first. These 500ma's unexpectedly did not appear as bright or as white as you would think with the 25% increase in amperage. In fact, after initial brightness, which was not any brighter than the 400ma's, they quickly faded to be dimmer than the 400ma SLS's, and stayed at that dimness for awhile ( I shut the lights off after about 45-50 mins). The corona appears to be pea green and the light yellow white. As far as extra heat goes, they did get quite cozy warm intially, but never hot (I was running the double AA configuration with two new alkalines), and before they got any hotter, after about 15-20 minutes, they started to cool down as the light became dimmer. If I were to let them rest, I could turn them back on and get about a minute of good brightness and then they would dim to just above the level of an ARC CPF AAA, but not as white. Therefore, I don't know if the higher amperage took all the juice out of the batteries in the first 15-20 minutes or if the circuitry caused the light to go into an extended run mode with the ability to obtain a short time of brightness after a rest period. What kind of light output curve should we be expecting from these 500ma's anyway? Is the circuitry making this an inefficient configuration? BTW I did notice a slight flicker as the light appeared to gear down into the dimmer mode (I am not talking about moon mode here - more of a reduced sun mode). This was after resting the light and turning it back on, and letting it run a minute at good brightness.
