Hyperion CE-R
ernsanada
I just got the Hyperion CE-R Supertactical
Shipping took 6 days. From ordering to actually receivng the order took 17 days. Order #110
From Supertactical's website,
$32 Included Shippment
Main features:
Color: Dark Grey
Using Cree P4 LED and reflector, fixed focus
Surface: Type III hard anodized finish, highly durable
5 Output Levels: 80 lumens (2hrs) -> 20 lumens (20hrs) -> 140 lumens (1hrs) -> Strobe(15Hz) -> Standby (flash low every 10 seconds)
Water-resistant (10M )
Uses one CR123Aor 1 X 16340 rechargeable battery
Reliable twist switch
Size : 6.9cm Length, 2cm diameter
Weight: 35 g (excluding batteries)
Fit and finsih is excellent.
Type III Hard Anodize is excellent.
Thread action is very good.
Comes with 1 o-ring, 2 foam pads and lanyard.
Top, Hyperion CE-R. Bottom, Jet Beam CL-E
Fits AW's Protected RCR123 with ample room.
Left, Hyperion CE-R. Right, Jet Beam CL-E
Left, Hyperion CE-R. Right, Jet Beam CL-E. My Hyperion CE-R head will not fit on my Jet beam CL-E body and vice versa.
Left, Hyperion CE-R. Right, Fenix P1D CE
I just measured current draw on a freshly charged AW Protected RCR123, 1.57mAh.
These beam shots are using freshly charged AW Protected RCR123's.
Hyperion CE-R @ 79"
Fenix P1D CE @ 79"
Hyperion CE-R @ 79" Stepped down exposure.
Fenix P1D CE @ 79" Stepped down exposure.
Left, Hyperion CE-R. Right, Fenix P1D CE @ 79"
Left, Hyperion CE-R. Right, Fenix P1D CE @ 79" Stepped down exposure.
The Hyperion CE-R got very warm while taking these beam shots. The Fenix P1D CE not as warm
I really like the UI of the Hyperion CE-R. The light remembers what intensity was set last.
The modes on my light are medium, low, high, strobe and blinking.
The bean is very smooth.
Excellent pictures as usual. You are number one! :bow:
My Hyperion has been shipped Monday (order #188) so I guess I'll have to wait a while....:sigh:
this little thing is heat up pretty quickly.
so what i did to cool it off?
i put it in the water about 3 feet deep and it cool off just for few seconds :D
lucky this thing is water-resistant :D
The only drawback to the Hyperion CE-R is lanyard holes are drilled crooked.
My holes are crooked as well, wonder whats up with that. Someone did not line something up right. Not a big issue to me though.
Just got mine in the mail. Fit and finish, general quality, etc are nowhere near what the old Arc LS lights were, but it is bright, white and a good value.
I'm starting to think these are drilled this way on purpose. I'm not sure what the purpose is though. The reason I think so is because it is exactly the same way on the C-LE.
