FreedomFighter
To make a long story short, I'm a retired military guy who has wanted to learn electronics his whole life and never had the time, but recently I've decided it's time to learn. I've been online for hours upon hours, days upon days searching and learning and have a little project going I need some help with.
I recently purchased a new snow plow for my truck and primarily as a learning experience I've decided to build my own amber LED mini-lightbar. I've been posting my progress on another website and videos on Youtube (Baystater116) and this is what I have done so far:
Using 5mm 14,000 mcd LED's I built a 40-LED array and tested it wired up to a Sho-Me 27 pattern flasher and it worked pretty good. Wanting to go brighter, I just made another LED array this time using 30-140,000 10mm LED's and just had both arrays wired up and running with the flasher. Interestingly it appears that the 40 LED 5mm array seems brighter and more effective at distance than the 30 LED 10mm array. Either one still does not seem bright enough for what I want, especially in daylight.
So I've now decided to go with what I'm hoping are more like what the name-brand companies are using and what they refer to as "Generation 3" LED's, primarily per a suggestion that someone made (I think he is a current member here). I'm trying to keep a couple of things in mind, first I'm trying to keep it simple. Second, is that the Sho-Me flasher is a two-channel unit that is rated at 3 amps per channel. I'm looking at purchasing the following items and want to know if they will work together well and if I am on the right track here:
1. I want to purchase 30 of these: LED's
2. Also, a total of 30 of these (10 per pack): Optics
Are these two items a good starting point or would anyone recommend something else? I will ask other questions/need help later, but for now I want to get started on this new project.
I've learned a LOT on this website already! Any help would be greatly appreciated.
Steve
Steve
