batmanacw
With all the Quark malfunction threads, I figured I would get in on the fun. I decided to figure out how to make my warm Quark 2AA tactical malfunction.
Not just so I would have a reason to send a light back, but so I could figure out what may be some of the issues that people have been dealing with. This is a way of being fair to those who have had issues and maybe we will find ways to fix this stuff easily.
First, if I leave the tail cap slightly loose, I will get some flickering if I tweek sideways on the tail cap. If I tighten it snug, the issues go away. I have the clip retaining ring pretty snug as well. If the clip retaining ring is too thick of out of shape, that could keep the ring from going all the way down, thereby keeping the cap from sitting properly on the end of the tube. If this was the case I would temporarily remove the clip and see if the light starts functioning.
Second, I have the low range set on medium and the high range programmed for high. If I have the light on high, then only slightly turn the bezel back to low, I can pull backwards on the bezel and get the light to trip on to turbo via the slop in the threads. Not sure why, but it does it reliably. The switch will turn the light off, but you cannot switch modes once it kicks to turbo.
Fixing requires turning it off for a few seconds and the head resets for some reason. It goes right back to running flawlessly. If I turn the head 1/4 turn when switching to low range, I will not show this malfunction at all. If I wiggle the head at 1/4 turn I can get it to very slightly flicker, but I don't want to break anything by tweeking super hard.
I also tried to get the same loosened head malfunction on my regular Quark 2AA. I was able to get the same malfunction. Just turning off the light for a few seconds seems to handle it. The light looses its modes until you turn it off.
The point to this exercise was to figure out how some of the complaints could be happening and how to fix them.
Both of my Quarks are functioning just fine now and now I know how to fix them if they freak out like they did when I forced a malfunction.
The process of forcing malfunctions does not make my leery of these lights. It actually makes me even more comfortable with them. Now I know how I can affect the light and how to remedy the situation. Just thought this would be of interest to folks here. :candle:
