i finnally pulled the trigger
bouncer33441
some of you might like my upgrade some of you may not. i ordered a cryos cooling bezel , a crenulated strike bezel , and a ultra clear glass lens for my surefire g2 flashlight . it already has a 460 lumen led drop in waiting to go in , i plan on using rcr 123a batteries with this set up . that was just a cree xml drop in i ordered from battery junction . i eventually would love to get a triple or quad p60 drop in that will be 1000 plus lumens .
With that much of power, it's a good thing you're using the Cryos bezel. Every bit of that '40% extra surface area' in the Cryos bezel will be needed since most of your flashlight is made of nitrolon.
Sent from my iPhone using Tapatalk, please pardon typos.
that model cryos increases surface area 60% not 40%
Even better then. Any pics of your set up? I always like the look of a Cryos bezel with a crenelated bezel ring.
Get a metal body if you are planning to use a high-powered drop-in.
Batteries produce waste heat during use. The more current the drop-in draws from the cells, the more waste heat the batteries will be producing. The Cryos bezel will help dissipate heat generated by the drop-in, but the heat generated from the batteries won't be dissipated efficiently if you keep them in the polymer body of your G2.
Oveready sells bored P, Z, and C bodies. Grab them fast, though, since Surefire no longer makes them.
You will also want to upgrade your tailswitch. Stock Surefire tailswitches can sustain up to 2.5A of current, if I remember correctly. High-powered drop-ins can draw a lot of current, from anywhere between 3 to 5+ amps, so stock tailswitch will not be sufficient. McClicky is able to handle up to 5A, so that should also be on your shopping list.
yes i plan on moving everything over to a bored out c2 body with a triad tailcap both hard anodized. then i will be able to use my rcr123a's as well as my 18650's .
i also can use my b65's with the original host with the surefire nitrolon extender . i would like to get the an 14 extender i believe that would help cool the light better then the nitrolon one , if that is the aluminum one .
Awesome. Glad to hear you're gonna enjoy your light.
Ain't we all love Oveready?
i made a mistake the extender i have is the an14 nitrolon 1 will the a14 aluminum 1 fit my g2 to help with cooling
as opposed to a bored c2 or 6p body would a solarforce l2 or l2p make a decent host for this set up
