Ideas for 12volt power outage lights
LightCrazy
USA, Western PA
I have some 12v 33 amp hr batteries I have hooked up in parallel and have them ready for emergency 12v charging of 18650 batteries, cell phones, etc. if the power goes out for an extended time. How about some economical ideas for 12v lighting I could use to light up a few adjacent rooms if needed. Anything similar to strings of Christmas lights run on 12v? Thanks. I have four total of the 33amp hr batteries.
I'd love to hear more details of your system. I was without power for 3 weeks after Sandy, and swore to build such a system, so I could charge flashlight batteries, etc..
For lighting, I'd suggest looking into LEDs made for automotive or marine use.
You can use MR16 12V lights as a backup light from 12V.
There are 3W-5W even 9W versions. I hava mine from DX.
My power outage lights are those 12V 13W florescent worklights Bayco brand.
pros: Cheap, alot of light, draws ~1A, 10ft cord, rocker switch, 12V cigarette plug [which can be easily modified and spliced into the control box.
cons: Not weather resistant at all [hope your roof is still up], not shock resistant at all [hope you don't drop it on tile], designed for light duty [not for frequent outages], 7000K CCT
Power outage is sensed through a couple AC coiled relays, not the most efficient way of doing it but it is the cheapest. Batteries are mainly group U1 UPS batteries, 35AH [C/20]. The bedroom and the garage both has one 35AH battery kept on charge through an Attwood 1.5A maintainer/charger. After a long outage, I would drag the two batteries out from their storage locations and hook them to my Dual Pro 6A charger [three outputs]. It only takes 2 hours to charge back a 35AH after a 24 hour outage running only a ~1A load. The hardwired florescents has a tail long enough for me to drag it into the bathroom, hallway, or anywhere that needs light. A third 35AH battery is housed in a utility box with handles. It feeds a DC/DC converter that supplies 5V at 3A. With a couple receptacles, resistors, and PTC fuses, the DC/DC converter feeds 5 USB ports, which charges up to 4 AAA/AA Eneloops through the Eneloop USB charger, a homemade Max1811 based Li-ion charger for AW17670/18650s, custom configured one port to charge my Iphone 4S at 500ma/h and one to charge my ipad at 1000ma/h. Assuming all 5 USB ports are occupied, its still only a 1.5A drain... and the 35AH can take a load like this for about 10 hours. It pretty much shrugs it off unless you load it with say... five amps.
In the last five years, we've only had three outages, and only one that gave the batteries a good run for their money. As a result, they have maybe 1/3 of their original capacity, and its a little :broke: expensive to replace at the moment :ohgeez:
Great ideas. Thanks!! Illum- you have valuable info and ideas. Now to save up some money. I have four of the 12v 35Ah batteries. So far I have three wired in parallel, but for just running a 18650 gather occasionally- more for the fun of it than anything, I really don't need all three together yet. Keep the great info coming.
Do they make plastic boxes to hold marine/car batteries that have a lid so you can run the wires into it, covering the terminals so they can't get shorted out, and with a carry handle so you can move it to where you need it?
How long a cord can you run to one of those DC shop lights before getting losses? It would be more convenient to leave the batteries in the garage and run a wire. Even run it behind the walls and punch down a DC receptacle.
I'm interested in 12v automotive lights that fit conventional auto lamp holders but are LED. Many styles and brightness on Amazon. Autozone, too.
