AilSnail
If you can make a poor man\'s runtime meter...
I can make an even poorer integrating light meter!
The apparatus is a 2"wide white paper arc over a photoresistor from Doug Owen. the stars were placed beside the PR facing the same direction. a collar is around the PR to stop direct light and to mount Doug's 50% filter.
three different badboys were used for a variety of amperages.
the bb500 has become a bit unreliable after i cut and reattached the fb pin, but it seems to be consistent when it works.
It looks like the filter does not remove 50% of the light in this application. Hopefully I can take some pictures of the setup.
Edit: I believe the decrease in light from 1250mA to 1450mA might be due to the low Vin of the BB700 and BB750.
The battery pack were 2x2 D alks.
The measurements were taken after about 3 seconds.
The units of R are Ohms of the photo resistor.
Double pole switches were used on the Vin and Vout of the badboys to quickly set the current.
Conclusion: Though the test method is probably riddled with error sources, it leads me to believe that parallelling wayne's boards to get more than 750 mA tohrough the single dies (1w and 3w) is an excercise in futility. I don't know if the apparatus favors low domes, but it looks like it based on the flux bins.
