Hi Guys, Any help would be greatly appreciated...
Just getting into this LED stuff and I know absolutely nothing about it.
A couple of years ago, I wired up my old car with glowing decals and under seat effects, but it was all wired into a controller with batteries.
I hated that...having a couple of double AA's in a controller underneath your seat is just so amateur, so Ive been trying to get into things via wiring it into my cars actual electrical system...that being said, I have some LEDs that work and some that don't...
So, before I begin, I just want to say that all the LEDs actually work - Ive tested them using my old controller and they're all fine - they all light up using it - Its just some work and some dont when I wire them into my car.
Okay, so I got me a Fuse Tap - wired them all up and grounded them as youre supposed to do - and I've tried doing them all individually - and only one out of the three will work...Ive dug through forums, tried different fuses, different plugs different wires, etc. etc. - Im at my wits end...what am I doing wrong?
Im trying to plug them in to my instrument panel - its a 90s sportscar, so it has a nice little old school on-off, dimmer switch for the instrument panel... In any case, out of the three LED's I have - only one will work when tapped...the rest do absolutely nothing - Im doing all the same things with all of them, but still, only the one will work...I mean, theyre all supposed to be 12V...they should all work the same, right?!?!
Thoughts?? and please, talk to me like Im dumb because, when it comes to this stuff, I really really am apparently...just clueless at this point.
OH, and last but not least, some of these LEDs I bought months ago and just had them stored, so I wanted to test them to make sure they work - before I remembered I have a battery powered controller...I used a lithium battery and I have the same results - only the first one worked - the others, not even remotely....
So, that being said - thoughts? How would you guys go about wiring up - multiple LED's to that fuse tap that would actually work?
I dont want a huge amount of effects- I just want some of those tube LEDs running up my doors and around my dash, a couple of the #2 style LEDs under the dash to light up the floor, and a wire (probably attached to a key ignited electrical source so that it runs whenever the car is running) to the front of the car to illuminate my front decal...
Again, any help would be greatly appreciated....Im so so soooo out of my element here. I feel like a total idiot.
[/URL][/IMG]
