Imalent MS12 Flashlight - The King of Light
gearvita
The Imalent MS12 is one of the latest and brightest torches, also known as "the king of light". It is powered by 12 American Cree XHP 70 LEDs and can produce fan cooled 53000 lumens with a max beam distance of 913 metres. Built in high power cooling fan, silent, waterproof, heavy wind, which is a perfect combination of great energy and technology.
MS12 is extremely compact and comfortable to hold, utilizes 6 side lights for camping, fishing and more other outdoor lighting experience. It features Imalent's signature high-grade side pressure switch, this ergonomic design provides an unprecedented level of grip. Eight output levels ensure long runtimes with low or high output in any situation. The "hide strobe" feature keeps you safe by starting quickly at critical moments.
Main Parameters:
LED: Cree XHP 70 LED
Power Source: Built-in Li-Ion battery pack
Max Output: 53000 lumens
Peak Beam Intensity: 208000cd
Peak Beam Distance: 913 meters
Light Temperature: 6000 - 6500K
IPX Rating: IPX-8
Impact Resistance: 1.5 meters
Output and Runtime:
Turbo: 53000-15000 lumens ( 3+78mins )
High Ⅲ: 30000-15000 lumens ( 4+80mins )
High Ⅱ: 15000 lumens ( 1hr 36mins )
High Ⅰ: 7500 lumens ( 2hrs 45mins )
Middle Ⅱ: 3800 lumens ( 5hrs 45mins )
MiddleⅠ: 1900 lumens ( 11hrs 10mins )
Middle Low: 900 lumens ( 22hrs )
Low: 300 lumens ( 55hrs )
Product Features:
● Utilizes 12 pieces of American XHP70 LEDs, Imalent MS12 LED Flashlight comes with a lifespan of up to 5000 hours and a maximum output of 53000 lumens.
● Built-in self-testing intelligent charging circuit which is convenient, fast and safe.
● Eight power levels which can be changed quickly with instant turbo available.
● Six battery capacity indicators around the flashlight head, 360-degree shows the capacity any time.
● High efficiency constant current circuit maintains consistent brightness.
● Features a lock and unlock function. With the flashlight off, press the switch button 3 times, the red indicator will flash twice to indicate the flashlight is locked. Press the switch button 3 times again, the green indicator will flash twice to indicate it is unlocked.
● Built-in thermal control module automatically adjusts the brightness output to keep the unit from overheating.
● Combination of toughened ultra-clear mineral anti-reflective coated glass.
● Aluminium orange peel reflector.
● Aerospace-grade aluminium alloy body, wear-resistant Type Ⅲ hard-anodized surface treatment.
● Waterproof to IPX-8 standard (2 meters submersible)
Learn more about it on GearVita, if you are interested in it and want to bring it home, remember to use the coupon code "IMMS12" to get the $100 discount, which will give you a lowest price of $389.99 compared to any other websites. And when you received your MS12, it will bring you absolute shock in the night: https://gearvita.com/imalent-ms12-led-flashlight-53000-lumens.html
Related products:
nitecore concept 2
nitecore tm10k
