Sold/Expired Interested in a Surefire U2 adapter?
MorpheusT1
Norway
Can you give a confirmation on what kind of tube the adapter will be for?
I think a E-series adaptor would be best.That way a two stage switch can be used giving 12 brightness settings.
And it seems the custom makers are more into the E-series body.More available to play lego with :D
And TranquilityBase makes great 18650 tubes too :)
Benny
grnamin
McKinney, Texas
Currently looking at C, M and G series bodies only. That is, if the adapter can even be made. An E series adapter, if made, will most likely lengthen the overall form factor of the light because the threaded portion of the U2 head is about the same diameter as the E series bodies. You won't be able to screw U2 head into the E series body directly or vice versa. Wish I had a diagram for this. :) We'll see what can be done.
grnamin
McKinney, Texas
bad news...:(
I didn't have a C, G or M series body with which to test the feasibility of a U2 adapter until today. The adapter itself seems possible, but because the U2 head won't sit deep enough into the C, G or M series body, a dummy cell would have to be added, about half the length of a 123 battery, in order to bridge the gap and provide electrical contact. Sorry, I was excited about this project, but it looks like it won't get off the ground. :(
twentysixtwo
Michigan
HERE IS A REALLY KEWL IDEA!
How about a 18650 twisty tube. This would strictly be a tube, perhaps with a mushroomed base allowing for tailstand. There might be sume knurling or other scallops on this end to assist in twisting and also for lanyard attachment. O rings of course.
The other end screws into the head. This would convert your U2 into a twisty with tailstand while shortening it up big time.
I wonder what it would look like sized for, say, a Pila 150S?
Advantage: Shorter, smaller, lighter, tailstand, 18650 or Pila capability.
Disadvantage: Lose clicky, not much else.
.............\.....................................===| <- FLARED BASE
U2 Head.........|.......18650 tube..............|
crude ascii drawing above
