raggie33
*the raggedier*
- Joined
- Aug 11, 2003
- Messages
- 13,578
just wondering my ocd is asking
> more efencent then single?
no because multi emitter floods a wider area, so if both lights are at 1000 lumens, the single emitter will put more lux on a smaller target
to make up for it, the multi light needs to increase its power level, which means it is going to use batteries faster, and that is Less Efficient
the Lux (how bright the target is illuminated), is much lower on the multi light, IF both are set to the same lumens.
No. While some multi-emitter devices may have a wider beam than single-emitter devices, there is no technical reason why you can't have the same beam/field/spill angles in the far field with a multi-emitter source that you can with a single-emitter source (and in fact, this is reasonably common in non-flashlight applications). Now, there are certainly some tradeoffs that come up if you have a constrained optical system diameter, but that's a specific situation and not the general case.> more efencent then single? no because multi emitter floods a wider area, so if both lights are at 1000 lumens, the single emitter will put more lux on a smaller target and will look brighter. to make up for it, the multi light needs to increase its power level, which means it is going to use batteries faster, and that is Less Efficient the Lux (how bright the target is illuminated), is much lower on the multi light, IF both are set to the same lumens.
One other thing is if the emitters aren't the same
So, in terms of throw, a single is more efficient than a triple.
Trying to locate dog leavings with a thrower is like looking at Google Earth through a straw; trying to defeat inverse-square with brute-force flood snaps the pupils shut with foreground light thus something 100 meters away is more difficult to see than that same cd/lux at 100m away would be in isolation.
both are true:
2. Im also saying that a triple will use batteries faster, because it works harder, to cover a wider area
My primary use cases being indoor tasks, outdoor tasks on my ⅛ acre suburban lot, and walking the dogs on 2m leashes through the neighborhood I've got a number of triples and quads - the right tools for the job. My throwers only see occasional use at the folks' house in the country - and surprisingly little at that since sightlines are generally no more than 100m.That's why I use a flip-up diffuser on my Acebeam L-16.
This is not the case if you are far enough from the lights that the beams overlap. How far from the source this is depends on the beam angle involved, but the principles hold true for all beam angles. Building on your example, let us assume that your 4 lights each project a 10 degree beam that has a sharp cutoff at the edges and is perfectly flat across the beam. At 100', each light gives a 17.5' diameter spot. Since lumens are illuminance divided by area, the spot from the 1k lumen source is at 4.4057 footcandles. Now, if we assume that the 3 identical 333.3 sources are all aimed parallel to each other, and are in a line with the sources spaced by 2" (so the sources are at 0", 2", and 4"), we can approximate the resultant beam as an ellipse with a major axis of 17"10' and a minor axis of 17'6". Dividing the 1000 lumens from the 3 sources into that area gives a illuminance of 4.1998 footcandles, or a difference of just under 5%. That's almost impossible to see under ideal conditions, and with real beam shapes the difference is going to be even less pronounced. And the difference gets even smaller as the distance from the source increases. When one considers that the efficiency improvements from running LEDs at lower currents are real, and that there may also be driver efficiency improvements from running the LEDs at higher voltages (potentially 3x the driver voltage for the triple), it's pretty easy to overcome that 5% difference in illuminance even if the power to the LEDs is the same.maybe an example will help pretend I have 4 identical lights, each capable of two modes, either 333.3 lumens, or 1000 lumens... 1. pretend I use three lights, each with one LED, set to 333.3 lumens, and I tape them together into a triple bundle. each of the triple lights is producing 333.3 lumens, so three of them add up to 1000 lumens. But the Throw and Lux dont go up by 3x, because the beams are not focused together. 2. I use the other light with one LED, set to 1000 lumens, with a typical reflector with hotspot and spill. the three light bundle will obviously be dimmer than the 1000 lumen single, because the three lights are side by side, they dont stack up to get brighter, they just spread out a wider beam, each of 333 lumens.. a close range wall of light that totals 1000 lumens compared to the triple, the 1000 lumen single will be too bright in the center, so the operator will dial down the brightness to 1/3, to match the brightness of the three 333.3 lumen lights
