akula88
Is there a light with a UI that has an instant turbo toggle switch? which when turned off, goes back to the last 'daily' mode you were in?
-- essentially it will have these switches --
1. OFF/ON rear tailcap to turn-off the light or toggle thru the modes
2. Instant TURBO/HIGH that would override the above mode but would return it back when disengaged.
I have a Klarus XT2C and loves the dedicated STROBE tail button, while the main tail bottom does the mode cycling. However, it has no mode memory, and always defaults to HIGH from a OFF mode.
I recently got a Nitecore MT26 which has two modes by loosening the head/bezel. TURBO mode is accessed by tightening the head, while the normal/daily mode is accessed by loosening the head and cycling the tail switch. I'm not comfortable with the loosening the head. I believe Eagletac G/D25 also have similar UI.
The magnetic ring control would come close to my idea of instant turbo/high, but returning it to its previous mode would require fine motor skills or human memory. I'm talking abour Sunwayman M/V11R series, Jetbeam RRT, and Nitecore Infilux.
