KevinL
I've been looking at some packs. Forget about the light, but look at the battery being disassembled in these pictures:
http://www.candlepowerforums.com/vb/showpost.php?p=2815888&postcount=26
We are aware he is working on a 3S2P 18650 LiCo pack.
Third photo from the top he shows a PCB with red and black wires and a bunch of cells. I'm starting to wonder whether this large battery pack is, in reality, completely unprotected - that the PCB is just for wiring and not for protection.
I notice a red wire going to the PCB, black wire for ground. The white wire soldered from a terminal is actually for the charging connector. If I'm not wrong, the blue wire from the charging terminal should also be soldered directly to ground and thus the battery pack. Green wires in the background have been identified as an on/off switch.
As I understand, PCB protection circuits have taps to each individual cell to ensure that they are balanced and one cell is not overdischarging. This pack doesn't appear to have the array of wires required for such a circuit.
Am I correct or totally off base? I just need to know whether it is, so I can manage the pack appropriately - if it's unprotected I need to be more careful that's all (been working with unprotecteds for years, and a little caution is needed.)
