JetBeam DDR30 (pictures)
Mar
BC, Canada
I just got it a few days ago so haven't spent much time with it but here are some pictures. Certainly very bright and appears well built. No memory mode so always starts on high, Constant output, haven't done a run time yet.
Beside the Nitecore TM15
DDR30, a rechargeable digital display three-headed flashlight, is the world's first digital display LED flashlight with high lightness up to 3200 lumens. It is under the patent protection of JETBeam’s unique digital display of the brightness and the remaining power level. With the display function, the users can see the mode and remaining power clearly at any time. DDR30 can be charged directly. It offers three brightness levels and one strobe mode with an easy operation regulation of side control switch. It adopts 3 latest American’s Cree U3 LEDs, max 3200 lumens, 60 hours run time. DDR30 extended the classic of RRT3 and became another miracle “rechargeable digital display three-headed flashlight of 3200 lumens”
Feature:
  • Adopts 3* Cree U3 LEDs, Max 3200 lumens
  • Advanced digital display system, under the patent protection.
  • Display output mode
  • Display battery power
  • Easily operation of side control switch
  • Rechargeable design
  • Waterproof to IPX-8
Specifications:
  • Light source: 3*Cree U3 LED
  • Beam distance 450m
  • Intensity 45000cd
  • Battery: 3*18650
  • Output regulation: Side switch
  • Circuit design: Constant current circuit, constant brightness.
  • Working voltage: 9-19V
  • Waterproof: IPX-8
  • Body: Aerospace aluminum
  • Dimension: 164 mm (L ) x 67mm(D), weight: 480 gram
Note: The above-mentioned parameters are approximate and may vary between flashlights, batteries, and environments. Output & Runtime:
  • Function High Middle Low Strobe
  • Output 3200 LUMENS 500 LUMENS 30LUMENS 3200 LUMENS
  • Runtime 2h 10h 60h
Operation:
  1. ON/OFF: Press down the side control switch for 2 seconds to turn it on.
  2. Mode selection: While the light is on, quick click to switch the modes, double click to access the strobe mode.
  3. Mode display: Display the current mode with the flashlight on.(“H” means High mode, “E” means Middle mode, “L” means low mode, “S” means strobe mode.)
  4. Power display: Display the mode for 5 seconds, then display the remaining power level.(“0~9” to display the remaining power level,9 means full battery power, 0 means low power, there is flash warning at low power status.)
  5. Momentary on: Half press the side control switch at OFF status to momentary turn on the flashlight.
Your images are too large and have been replaced with links Please resize and repost.
See Rule #3 If you post an image in your post, please downsize the image to no larger than 800 x 800 pixels. - Thanks Norm
Mine is still in the mail from BJ, but should be here Tuesday. Then I'll have something to compare my new Thrunite TN30 XM L2 against.
How do you like it? Do you think having only 3 modes limits it?
I have a TN30 but in NW, Jetbeam definitively is brighter. Both seem to use the same reflector if that is possible. I don't think 3 modes is a disadvantage, it is just a simple light to use and anyway depending on my needs I have 20 other lights I can choose from.
Will try to see how I can resize my pictures and post more, those I had on here were the default setting.
Hey there Mar - Many thanks for posting! I'm looking at this light also and have a TN30. How's the size compare? You also say brighter - are we talking about considerably brighter or just slightly? The UI also does look nice - just wondering if it can take hi for longer than 10 min. at a time... Many thanks RC
As i said my TN30 is the Neutral White version, rated 2780 lumen, totally different shade of light. The DDR30 out throws it, practically the same coverage for flood and I would say much brighter. It also has constant current so as long as batteries have power it should stay on hi for 2 hrs or so the specs say.
The bodies are same width for both light, both tail stand.
Tried reducing picture size, hope this works.
This is perfect! Many thanks for the feedback - I have the cool white version which i'm guessing would be closer to the DDR30. Nonetheless - I like having a switch in this form, so I'll probably wind up going for the DDR30 quite soon. Having it be a little shorter won't hurt either. Many thanks for taking the time to send!!
The holster of the 4Seven S18 fits the light perfectly as one does not come with the light. Pretty certain the TM15 holster would also work just fine.
I just received mine yesterday and I love it except for the fact that it has no memory function. To always turn on a light this bright at full brightness is annoying, especially when you have to hold for 2 seconds for constant on. I love the spacing of each level. 3 levels is fine for me. Very simple interface, easy to use, awesomely bright and I love beam profile and ratio of flood to throw. And I found it for $200 shipped so it was cheaper than my RRT3! It would be my favorite light if not for the lack of the memory function.
