Henk_Lu
I got a Jet-III M Ti for christmas, bought it on the Marketplace. The light is mint, but unfortunately, it has a preflash.
I don't talk about a little blink here which you only notice if you pay attetion to it, no, it preflashes at full power regardless of the level you programmed. The light would be unusable on low that way.
I did a reset sevral times, doesn't help. The flash is present in both modes while it's not that noticeable at 100% of course. I emailed Jetbeam, they can only tell me to try several things like changing the cells and the switch, no change. I guess the brass ring can't be removed from below, that you have to remove the light engine from the top?
Now I don't want to send the light in, if the preflash doesn't hurt the light, I'll keep it like it is. It doesn't hurt the light, does it?
Does anybody elses' Jet-III M Ti has that brutal preflash?
