I don't really understand, why do you need a standby mode ? Why not just turn it off ?
Thank You for the post gopajti.
I wonder if the smooth reflector version will throw a further distance than the OP reflector? You would think the smooth reflector would, but after changing reflectors from OP to smooth in my Olight M20 XML, the short term throw was better and overall throw distance remained the same.
I only see one spec for throw distance for the RRT-2 @ 155m.
So...
RRT-2 XM-L --> 2 cell light --> 460 lm
RRT-0 XM-L --> 1 cell light --> 550 lm
Something doesn't seem 100% logical about that. :thinking:
It will make more sense after they tell you the runtime for the RRT-2 XM-L with 2 x RCR123.
For the RRT-0, it is 20 minutes with one RCR123.
Standby draws 0.7821 milliamps or 782.1 microamps. With a 3100mAh cell this would take 165 days to sort of empty the cell.
This is one solid bugger! 161g vs the usual 120-130g.
Yeah Peterhaevey73, i guess it's quite high on paper and they never bother to optimise the driver more. Just have to remember in reality not to standby for more than 5 months. LOL! :D Seriously before you need to use the light for an event, one tends to recharge the cells. (and bring more cells)
But seriously i purchased the light as i needed a really really tough one that does not break the bank. So this "issue" does not really bother me, just turn it off with the rear clicky and problem solved. I can't justify the Elzetta ZFL-M60 as it is twice as expensive and also twice as dim.
I am interested in this light and also noticed the extra weight, in fact, this series of lights are getting heavier and heavier :
3M XML ==> 118g
RRT 21 ==> 137g
RRT 2 XML ==> 161g
So, are the extra 30-40 grams noticeable in everyday use ?
