JilLite Leviathan Review (Scuba light)
iso9009
South Korea
LED: SSC P7 D-rank / 800 - 900lm
Color: Three options / 5350K, 6050K, 6700K
Material: 6061 T6 Aircraft grade aluminum
Finish: Hard anodized Type III(Black)
Revolver switch - Titanium Ion plated
Water resistance: 150M (200M test passed)
Lens: Polycarbonate(5T)
Run time: 2hrs at maximum brightness / 60hrs at minimum brightness
Battery type: 2XLi-Ion18650(Rechargeable) or 4XCR123A(Primary)
Dimension: 225mm(L) X 53mm(D)
Switch: contactless magnetic sensor type
Brightness adjustment: Continuous brightness adjustment with turning revolver switch
Safety function: built in pressure valve in tail cap
JilLite Leviathan VS UK sunlight C4 eLED
PrincetonTec Tec40 VS JilLite Leviathan
LED: SSC P7 D-rank
revolver switch
Pressure value built in tail cap
1. surefire M4
2. JilLite Leviathan
3. surefire M3+A19
4. surefire 9P+A19
5. surefire L5
1. JilLite Leviathan
2. UK Sunlight C4 eLED dive light (6 watt white LED )
3. JilLite Qohelet XT + Scuba gear switch
4. Princeton Tec Tec 40
5. UK Mini Q40 eLED Plus (2 watt LED)
JilLite Leviathan (LED Color 5350K)
TV(shutter speed):1,Av(aperture value):2.8,Iso speed:200
JilLite Qohelet XT + Scuba gear switch ( Cree XR-E Q5 )
JilLite Leviathan - UK Sunlight C4 eLED dive light (6 watt white LED )
JilLite Qohelet XT - Princeton Tec Tec 40
1. Surefire M6 ( MN21 )
2. EagleTac M2XC4
3. JilLite Leviathan
4. JETBeam M1X
EagleTac M2XC4
JETBeam M1X
Surefire M6 ( MN21 ) - EagleTac M2XC4
JilLite Leviathan - JETBeam M1X
EagleTac M2XC4
JETBeam M1X
EagleTac M2XC4
JETBeam M1X
EagleTac M2XC4
JETBeam M1X
Nice review. i was really curious about this one.
It looks like it has one hell of a doughnut hole at those ranges. I think the LED's aren't quite focused properly. It may just be your light, but It'd keep me from buying it (if I ever went diving), unless it was just a one-off defective one.
~Brian
You did good job! Thanks.
The pictures are very fine to compare the beams of your lights.
Also you have good 18650 Li-ion rechargeable batteries made by Jil-lite. :)
Great photos and comparisons! Bet a lot of folks were wondering what was going on.:thumbsup:
Wish you had a WiseLed Tactical in the underwater shot....
This should go in the review section fast.
